Size of 2000 es300 door speakers
The vendors don't seem to have information on the old ES. You can fit 6.5 or even a 6.75 in the front lower doors and 6.5 in the back doors. There are tweeters up top in the front doors, you can pop a cover off to see what you can fit in there if you use a set of separates. Subwoofer in the deck you can fit an 8" in there. The speakers have specific mounting plates, so you'll probably want to get a set of Camry speaker adapter mounting plates for the doors. Clearance is pretty good so you can fit a nice speaker in there, but check with the window down when you mount them, to be sure there is no interference.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Tons of others you can find via search
https://www.clublexus.com/forums/es-...aker-size.html
https://www.clublexus.com/forums/es-...-speakers.html
dmatthews
03-27-08 10:16 PM
UncivilizedAMD
01-09-03 01:42 PM
