How to adjust Ignition timing on 2000 ES300?
My car became bit sluggish and I hooked up vacuum gauge to check everything is ok but on idle it is reading about 23 to 24 -Hg which is bit higher than ideal vacuum 18 - 22 -Hg. Book says clogged air intake or overly advanced ignition timing but the air filter is brand new so it should be ignition timing. How can I adjust that timing?
I got it only 6 months back and it has 120k miles on it and previous owner said they changed timing belt at 90k. I changed spark plugs, fuel filter, trans fluid, valve cover gaskets recently and it is still bit sluggish especially when merging on freeways. No engines codes till now. So I checked with vacuum gauge. Somebody on other forums said it may be because cams & crank may not be perfectly aligned when they did a timing belt job. Could that be a problem and is it easy to open timing belt cover and check?
Listers
GX - 1st Gen (2003-2009)
19
02-22-17 01:48 PM
BDSL
06-02-12 03:14 PM
1LS400Lexus1
01-23-03 05:01 PM
