1995 es300 power steering question
I have a 1995 es300 has anyone ever done a power steering line and reservoir swap as I have the dual output and return lines and the two return hoses that connect to the reservoir are cracked and I wanted to know if there is a way to change off for the one high output and return lines and along with changing for electric fans. Any information would be amazing!!
1996 Camry V6 has electric fans but you'll need to swap a boat load of parts including at least one electrical harness, radiator, fans, fuse box, relays, reservoir, power steering pump + lines. WAY easier to repair what you have.
OnebootWVG
01-29-12 10:52 AM
