02 ES300-front wheel bearings pressed in?
Dysfunctional Veteran
Is there a way to replace the entire hub assembly on the 4ES? Both my front bearings are out and I would like to DIY it if I can. I don't have a press or a vise though, so if the bearings have to be pressed in, then I will have to take it somewhere to have it done.
If you don't have the tools then remove the knuckle and take it to a shop. Yes the bearings are pressed in.
M K S
02-11-16 06:43 AM
