ES 300 2000 Headlight Leveling System
How many sensors (height sensors) are in a Lexus ES 300 2002? Is there front and rear or only rear ? And where is the front one ?
Thank you very much, because for 2 days I was looking for the front sensor like a stupid , but the question is how to set the rear sensor if there is no place to regulate. Because from the moment I repaired it, my headlights aim into space and "AUTOMATIC HEADLIGHT LEVELING SYSTEM WARNING LIGHT" is on
adamsbls (06-15-19)
Thanks to you I have solved the problem with my headlights . But I had to use some washers to get the sensor in the right position in relation to the control arm after I put manualy the sensor exactly in point zero (middle position) .Thanks again very very much
Hi,
Glad you were able to solve your problem, but it should not need so many washers. None at all honestly. I'll post a photo of mine for reference.
jimdwright
06-12-19 11:35 AM
lostape45
04-02-15 12:25 PM
