Rear brakes and rotor replacement
Where can I find a good video on how to change rear brakes and rotors on my 2006 es330. YouTube isn't a big help, unless 2005 es330 has the same set up
Pretty much everything 02-06 is the same. The rear brakes are nothing special - any generic disc brake how-to will get you through it.
Be sure to clean and re-grease the caliper pins, and make sure the caps are not torn. Replace them if pitted and caps if bad. This is often overlooked and can lead to problems.
Dinomon
04-14-10 06:37 PM
