01 ES300 time for new struts
Starting to start looking to going over the front end on my 01 ES300 with 245K. Front end bottoms out on a small bump occasionally. Actually leaving work at a red light turning left onto a boulevard if I don't take it slow it'll bottom out. That's Bought a set of Mastercraft VSR grand touring tires few weeks back and had them mounted. Tire wear was even, but about the time a few months ago when I first started having what I'm pretty sure is warped rotors, I started getting a slight vibration at about 60-65mph. Stayed there after new tires, so need to look elsewhere.
Also just this week I'm getting a slight clunk from the rear struts just going down the road at lower speeds. So the question I have now is what are people using for struts now. Initially I thought just replace the struts and bellows with KYB's up front and reuse the insulator, seat and mounts. But I'm really wanting to get a quick strut for ease of install. Problem is not many good quick stuts are out there for the ES300's. Looking at KYB quick struts for a Camry XLE with V6 looks to be the best I can find. I'm looking to do this once and forget about them for the next 200k as I drive 75% interstate miles 60 a day. Any thoughts?
I've heard the same for both expensive and cheap struts, they all last about the same so, the only thing I could add is make sure you use a quality tire. A good high quality tire will greatly help with road feel while working with the struts. good luck
Dont reuse the mounts. My rear clunking was caused but sway bar bushing and mounts. I replaced all my struts with KYBs and front OEM mount with rear KYBs as OEM was just way too expensive. Dont cheap out if you planning to keep the ride for while.
paulbot (11-06-19)
Only the front has bearing mounts (re-use them if they aren't giving problems if you are not quick-strutting; and if so, still keep the old ones in case of problems). The rear "mount" is just a molded stud assembly, not like the front bearing mount. Confusing nomenclature here.
Also, understand how critical it is to get the upper strut mount bolt torque right. So many complaints I see are from DIY jobs where I do not see the expressed mechanical ability to get that right with complex tools or with the suspension loaded/unloaded.
paulbot (11-06-19)
Yeah that was kinda tongue in cheek in my reply. Reading back over the first post what I really meant to ask was is it fine to use KYB quick struts for Camry XLE because I can't find a listing for ES300 any more. I do see the strut itself in the Excel G is the same for 97-01 Camry es300 Solara and Avalon models so I assume it will. While I have not done this job in the past, I am pretty good at following guides so I'll heed your advice.
daredeil95 (11-07-19)
brianatae
11-24-14 08:24 PM
