Starting Problems in Hot Weather
Old 08-23-03, 03:26 PM
djmb
djmb's Avatar
Angry Starting Problems in Hot Weather
My 2000ES starts normally in regular weather or when parked in doors but stalls during starting when sitting outside in the hot sun. Ultimately it will start after a few attempts but it has touble catching.
The battery is new.
Does anyone have any answers for me?
Old 08-23-03, 07:55 PM
steviej
steviej's Avatar
I wonder if it is related to fuel pump or fuel pressure at start up. Easily measured if you have the right tool.
steviej
Old 06-06-04, 04:21 PM
mek88
mek88's Avatar
Question STARTING PROBLEM WHEN PARKED UNDER THE SUN
I also have the similar problem with my 1999 RX300 @105k Miles.
When parked under the sun during summer, I have to step on the gas pedal for 10-20 sec when starting the car. Otherwise the engine dies. I plug the scanner, and there is northing wrong. I also checked the relay, fuses, spark plugs, air filter and fuel pressure. Everything seems normal.
Please help me!
Thanks
mek88@yahoo.com
Los Angeles
Old 06-06-04, 05:18 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Default Re: Starting Problems in Hot Weather
The battery is new.
Sounds like you're experiencing vapor lock.
Old 06-06-04, 07:48 PM
mek88
mek88's Avatar
Question vapor lock?
May I know how to fix this vapor lock?
Is there anything need to be replaced?
Thanks
Mek88@yahoo.com
Old 06-07-04, 09:49 AM
lexusk8
lexusk8's Avatar
mek88, you might want to take a look at your throttle body. It could very well be that inside the body is filled with carbon, grime and fuel vapor, and so needs to be cleaned out. A bottle of specialized carb/choke/throttle body cleaner is sufficient for that task, and you can get it at your local auto parts store or Wal-mart. Also, while you're at it, check the air filter and its condition. If it's quite dirty, replace it. Let us know if you have any problems.
Old 06-07-04, 10:26 AM
mmarshall's Avatar
Default More possible answers
What kind of gas are you using? Some brands, octanes, and mixtures are more susceptible to vapor lock than others. Try a different brand and see it that helps. Chevron and Mobil have good detergent additives. Amoco ( now with BP) traditionally has done an overall high-quality fuel.
Also have the Coolant-temperature, mass air-flow, throttle-position, and oxygen-sensor checked. Even though you didn't get a scanner code, sometimes these items can malfunction and not show up on the scanner.
Old 06-07-04, 10:43 AM
mek88
mek88's Avatar
Question Starting problem in hot weather & / when engine hot
I always use Chevron, and I just put a bottle of Techron fuel cleaner less than 1000 miles ago.
Now, I notice more problem:
After driving for a while, I stopped @ a store for 10-15 minutes, then the engine fail to start. I have to press the gas pedal for 10-20 seconds to keep the egine running.
So now, not only it is hard to start when engine is cold & the car parked under the sun, but also when the engine is hot.
And it seems these problem occur more often than ever before.
In the morning & at night, the 99-RX300-AWD starts fine.
Do you think the main relay or Fuel pump relay need to be replaced?
I've run a search on the internet and found the similar problem to Honda Accord at: http://autorepair.about.com/cs/troub.../aa010301a.htm
May I know, where is the location of the main relay?
I found an EFI relay on the engine compartment, but I couldn't fine the main relay.
Thanks
mek88@yahoo.com
Los Angeles
Old 06-07-04, 02:46 PM
steviej
steviej's Avatar
have a shop measure the fuel pressure upon cold startup and when hot.
mmarshall's got some ideas, too. I especially like the coolant temp. sensor. It is true that even though a trouble code is not sent, the sensors can be lazy and send misinformation to the ECU thus changing the fuel/air settings.......and badda bing badda boom.....stall or no start.
steviej
Old 06-07-04, 05:40 PM
gmac1337
gmac1337's Avatar
This problem happened on our 2001 rx300. The engine would struggle to start but it wouldnt work in hot weather. Had lexus attempt to repair it three times but nothing worked. Ultimately the problem stopped but it sure was frustrating when a brand new lexus does not start. Best of luck with your problems.
Old 06-07-04, 07:38 PM
flipside909
Lexus Connoisseur
Default Re: Starting problem in hot weather & / when engine hot
Thanks
mek88@yahoo.com
Los Angeles
This definitely sounds like some sort of electrical sensor problem. Have you looked at your MAF sensor lately? When the little probes get dirty, they tend to trip out the ecu give you that no-start symptom. Have you gotten a diagnostic check lately?
Edit: Coolant temp sensor usually just affects your engine fans and erroneous guage readings.
Old 06-09-04, 11:28 AM
mek88
mek88's Avatar
Default Starting problem after parked under the sun
I found a similar situation with me, not sure if this is the correct solution on my Rx300:
https://www.clublexus.com/forums/sho...arting+problem
92blacktt
Performance & Maintenance
09-09-16 03:56 PM
KK76126
NX - 1st Gen (2015-2021)
12-24-15 05:08 AM
tomtheslac
09-13-10 10:14 AM
GS400Star
01-28-09 12:28 AM
kathleenkmh
05-23-02 05:31 AM
Quick Reply: Starting Problems in Hot Weather
