Replacement light for luggage compartment
What is the part number for the trunk light? Looks to be an entire unit and not just a bulb that gets replaced. 1997 ES300
edit - that might be wrong I'll check my car in a bit. Yep it's wrong here's the bulb and part number
90981-14009
There are probably LED versions in that form factor
edit 2 - bulb is approx 6mm x 31mm
Hmmmm. The square light fixture appears to be one unit. I guess what you're telling me is that I can pull the lens cover off the fixture and replace just the bulb itself? I tried doing that but the lens cover seems to be attached robustly to the fixture.
The cover comes off I removed it with my fingers or you might want to use a flat tool. Be patient, if it's cold use a hair dryer to warm up the plastic.
LimpnLexus (01-12-20)
