2002 es300 multiple misfires, losses power & makes hiss sound when accelerating.
8th Gear
Short version:
My 2002 es300 had multiple misfire codes so i changed the spark plugs and checked the coils. I then got DIFFERENT multiple misfire codes and i could occasionally smell gas while driving. Changed bank2 OCV & gas smell went away. Now it is loosing power and making a hissing noise when i press the gas. Any ideas on how to fix these issues would be greatly appreciated. Thanks in advance
Long version:
codes on 11.19.2019:
p0300 - p0304, p0306 cylinder misfire, bad coil or spark plug or oil control valve [ocv]
p1315 #4 ignition coil
p0305 #2 ignition coil
p0430
A code P0430 may mean that one or more of the following has happened:
1 - The catalytic converter is no longer functioning properly
2 - An oxygen sensor is not reading (functioning) properly
3 - There is an exhaust leak
I changed the spark plugs, and the p0430, p1315, p0305 codes vanished.
I still had misfires [shaking], I smelled gas, and car loses power when accelerating. I can't go past 55 mph. I sprayed water around hoses looking for vacuum leaks and found none.
I changed the bank2 ocv trying to fix misfires and gas smell disappeared, but I still have the other issues & these codes:
p0300 - p0301, p0302, p0304, p0306 cylinder misfires.
The plugs, coils, and fuel injectors in the front [bank2] seem to be working, and the ones in the back were working when i changed the spark plugs last week.
I'm not sure if I should change the bank1 OCV, get a new front oxygen sensor, put fuel cleaner in the gas tank, continue to look for vacuum leaks or do something else.
Any help offered would be greatly appreciated.
Long version:
p0430
Short version:
Long version:
p0430
Long version:
p0430
- if hosed down engine bay with water u could've caused a electrical short somewhere.
- also check ur fuel pump,
- if its hissing sound u have hose leak, use a WD40 to spray around to find leak.
Defruky
RX - 1st Gen (1999-2003)
06-06-18 08:00 AM
