Whine from transmission area | 2000 Lexus ES300
Solved
First and foremost, I need to apologize for the delay and confusion. It did turn out to be a transmission whine, one of the shift solenoids in particular.
I realized that the sound was coming from the transmission when I took off the air box, then I looked under the car, and it was crystal clear that the sound is coming from the bottom of the transmission. I then tried to shift through gears while the key was in the OFF position, and the sound did change with each shift. With that, I disconnected the wiring harness for shift solenoids, and the sound went away.
This can also explain why EFI relay and TPS sensor are stopping the whine - EFI relay, or lack of thereof, effectively shuts the ECU, and the signal from TPS sensor also comes to the transmission, hence why it was also affecting the sound.
As of right now, the whine is not that bad, so for now I will leave it be, at least until the next oil change.
In the end, I should thank you all for al the help provided, I do appreciate it..
BMeek (04-25-20)
Curious. I'm still weirded out that something like a shift solenoid lights up upon key insertion! No one else seems bothered by that bit... is this part of a normal Lexus pre-start proceedure that normally happens quietly upon key insertion? If so, what else goes on?
I have no idea if that is true, that is just my guess made out of what I've seen so far..
P.S. Live and learn, to die a fool.. I never even thought of that before, hence why I was so against the fact that it may be a sound coming from the transmission... At least now I can sleep tight, knowing that it is not a ghost of some kind haunting my car.
Hope this helps and best of luck!
the ghost in the machine...
It's a paranormal remnant of when "the entire wiring under the dashboard was replaced.".
I would say it's more like a vengeful oddment of future expenses..
. But seriously, what a drag that must've been!
I had always assumed that key insertion sensing was all about security and lighting and don't-lock-the-doors-before-the-key's-removed. etc. Your theory is that Toyota implemented a POST back then and maybe found that priming various circuits a few seconds earlier makes for a smoother startup? I guess a modern Lexus could start all that when I walk up with the fob in my pocket or plant my butt in the driver's seat...
I want to hope that it is the case, since, in some circumstances, it can drastically cut the time it takes to diagnose some no-start conditions..
I know that some European Lexuses unfold mirrors and turn on valet lighting right when you approach the car.. Who knows what else they do at that moment...?
BMeek (04-26-20)
AabirRizvi
03-30-17 07:32 PM
