C1201, P0440, P0441, P0446 2000 Lexus ES300
I have a 2000 Lexus ES300. It has over 290,000 miles on it. I received an engine check light over a month ago along with the stability control off. I received the following codes when I had it read at AutoZone:
C1201 - Engine Communication Circuit
P0440 - Evaporative Emission System
P0441 - Evaporative Emission System, Incorrect Purge Flow
P0446 - Evaporative Emission System, Vent Control Circuit
I don't do maintenance or repairs on my cars personally, but it would be great for someone to help me determine what the problem is, how I could fix it myself or how much it should cost if done by a shop.
Thanks for your help in advance!
From another thread here on ClubLexus with the same codes... “These are the 3 codes you get when the evap hose is disconnected behind the air filter box.”
https://www.clublexus.com/forums/rx-...441-p0446.html
I had these 3 codes- evap hose was fine- ended up needing a new charcoal canister
widebody78
05-15-08 02:05 PM
