Blinking check engine light and rough idle?
Hi I have a 2003 lexus es 300. The check engine light has started blinking also engine is giving a rough idle. It feels like its jerking into gear instead of shifting smoothly. What could be the cause?
Hey,
I have had the same problem in my 2000 es 300. Mine was caused by a misfire in three cylinders, and a random misfire. I fixed it by first having it by replacing MAF sensor, the dead coil pack, and all six spark plugs.
Hope this helps
Edit - I should also add that I took my car to my local autozone and had them scan for codes. This was before I purchased any parts. As Arenii said, you shouldn't throw parts at a problem this complicated before knowing the codes.
Hope this helps
Hello,
For now it is just a shot in the dark.. Can you visit a local car shop and get the computer scanned? They usually do it for free.
Hope this helps and best of luck!
BROCKES300 (01-13-20)
djencee
05-22-16 07:31 PM
lbwagner
12-09-09 06:39 AM
