Rear sub modifications 4es
Hey all
I want to but in a infinite baffle (needs no box) 10” in place of my factory sub because it bottoms out and is aging. I was going to use a different amp. I was wondering if anyone here has done this. My question is
can I use the factory sub wires to high-input into the amp, or should I use rear speakers?
if I should use rear speakers, can I grab those wires behind the head unit or does the base model (Non ml) have an amp somewhere?
thanks =)
thanks =)
Hey all
thanks =)
thanks =)
Premium Sound system has AMP behind glove compartment.
OEM Sub in ES330 is 8in and not 10in.
You can connect aftermarket amp to cables feeding the stock amp. Just make sure the amp you get has High Level inputs. Auto sensing turn on: will turn on sub with radio and does not need remote wire. My go to are tiny Rockford or Kenwood for amp and 8in JL IB Marine sub.
Thank you so much! So grab a high in after the amp, to door speakers, NOT the wire at the current sub? Also, I know it’s 8 but I was going try to Adapt to 10. I am hoping to get a decent amount more base. Been cruising in an rx330 and a Prius (not mine, they’re for sale) and the bass in those is nice enough to make me want more in my car... don’t need to have 2 10s but a 50-75% increase would be great
I was thinking of making an MDF adaptor ring. But, in your opinion, is the JL 8" a substantial improvement? Also, a small piece of dynomat will help.
I am not looking for rap/hip-hop/techno deep bass or anything as I dont listen to those, just more depth to my typically rock music, oldies etc
MANY thanks =)
MANY thanks =)
MANY thanks =)
MANY thanks =)
https://filemail.com/d/xvoylfvubdqhzua
That’s awesome. I meant under the tray with the adapter and sub but you’ve got me sold on an 8”! For someone on a budget, do you think and 8” kicker comp 4om single voice coil is worth while? If not I can wait. I am going to start major surgery on my 1950 Chevy and there are always unexpected costs with that
JL Xmas is 14, kicker 8.6.
PlatSilvSc
12
11-13-06 01:32 PM
RA092423
09-26-06 04:18 PM
