Power Steering
Power Steering
Good morning. My son drives a 2003 ES300 and he told me his steering wheel was getting harder to turn. I checked the reservoir and the fluid was low, so I added some and that corrected the issue. Within a few days, I checked the reservoir again and it was low again. So we got the car up on jack stands and we found a leak due to a loose clamp on the hose going from the reservoir to the pump. We tightened it and then added fluid and everything was working well for a few days.
Then, the steering started getting difficult again. I checked the reservoir and it was full. I test drove it, and there is no squeeling sound coming from the belt. So, I am thinking it it is the pump. Does this sound like a good assessment?
And if so, is it ok to drive the car for a 3 or 4 days until we can change this out ourselves? Or is this critical and I need to get it to the mechanic asap?
Does anyone have a diagram of the steering knuckles for a 2003 ES300 and instructions on exactly how to lubricate? Would something like WD4 or Kroil penetrating oil or white spray lithium grease be the better choice for lubricant?
Is @HomerJay talking about the intermediate steering shaft?
https://www.japan-parts.eu/lexus/us/...&pa=4522033270
"steering knuckles" is not an actual part AFAIK.
Yes, the intermediate steering shaft. They look similar to this in the diagram. I would use spray silicone or lithium grease on the center points that rotate while turning the steering wheel.
I didn't know this was a problem on the ES. Some years RAV4 were/are plagued by the intermediate shaft seizing up.
LeX2K (08-05-20)
Is this visible/accessible from under the hood or is access needed from under the car? Do you have a diagram of the steering shaft to see where the joint is located?
I am working on a Hyundai with this problem tomorrow. They have notorious steering problems. Lubrication sometime solves the issue, but when not, a Canadian mechanic has found that tapping on the side of the u-joint can solve it (tapping modestly, with a hammer). Presumably this "re-sets" the needle bearings, and can fix some cases of binding that lubrication alone does not.
I have heard of some ES needing lubrication here; I wouldn't try the above unless that fails.
I had a similar problem with my 97 ES, even though there was no conclusion at that time, the thread which I started has a couple of comments towards the end claiming to have fixed the problem by lubricating the u joint
thread - https://www.clublexus.com/forums/es-...ttently-2.html
Hopefully this helps
Not having any problem but lubricated the steering u-joint on my 2003 ES300 with WD40 anyway to hopefully prevent binding. Thanks for the great thread, I'm sure it saved a lot of owners a lot of $$.
trk1
03-30-11 06:32 PM
OldSkoolGS
GS - 1st Gen (1993-1997)
14
03-11-04 10:28 AM
