04 Lexus ES 330 Static/Crackling Sound Through Speakers
2004 Lexus ES 330 (Sports Design Edtion) - Static/Crackling noise coming out of my speakers when my audio is on AND off. Any ideas as to what the problem is or how to fix? Thank you!!
Hello,
Do you still have a stock audio setup?
Not sure, but it sounds like a bad amp or the wiring to it. Try pulling AMP, RAD NO.1 and RAD NO.2 fuses one-by-one and seeing on which the noise will stop (here is a fuse diagram). If it will not stop with all of them pulled out, it would probably mean that the problem is elsewhere.
Hope this helps and best of luck!
Hello,
DelLexusSD
ES - 7th Gen (2019-present)
186
11-17-23 08:03 AM
