I have a fuel leak right under the fuel damper on top of the engine. Is there a special tool to get to the nut? It’s in a tough spot and hard to get anything over the nut to loosen it. 2000 ES300. Thanks.
Found this thread that talks about unscrewing the fuel damper on a 2003 Lexus ES300, though it has different intake design, so it may not work out for you. In worst case, you will probably have to remove a throttle body to get to it.
