2005 ES300 Original SAT NAV
Hi everyone,
I just bought a 2005 ES300 and I am considering changing the SAT NAV with something more modern. I want to know the dimensions to buy one that has the same dimensions because I don't want to change the plastic around it.
Can someone help with the dimensions?
Thanks
Thanks
Hello,
Every reputable head unit you will find on sale has its exterior dimensions written out in the specs, so what you can do is measure the opening you have already and check if a chosen unit will fit in there. If it is a little narrower, Metra made adapters to cover the excess space (P/N: 95-8202).
You can find more information about installing aftermarket head units here.
P.S. You are really lucky to have a stock navigation - the standard radio is embedded into that plastic, and to install a new head unit, a new trim needs to be bought, which is rare and excruciatingly expensive..
There’s zero need to get an OEM dash kit unless you want to pay that much for the little Lexus letters on it. And I’m crazy about using OEM stuff. I’ll take a pic of mine later on.
Hi everyone,
Thanks
Thanks
cpferris
10-23-08 09:44 AM
STAGED
04-12-04 05:01 AM
