Shaking Steering Wheel
I have a 2005 Lexus ES 330 with 128,000 mile on it. Lately the I noticed at higher speeds that the steering wheel would vibrate, or tug to one side. it is a strange feeling, I dont know how else to explain it, but I just want to know if anyone has had a similar problem.
Usually this is caused by tires, if you can swap the front/back see if the problem moves. Of course there are other possible causes like worn/damaged suspension/steering components.
Is your tire pressure okay?
Keeme123 (08-25-20)
I have already swapped the front and back tires a couple of months ago, and it’s still the same. I was thinking it could be the suspension but I don’t know how pricey those things could get. And I also don’t know what parts of the suspension would need to be replaced
I still think it’s the tires but the suspension is pretty simple and cheap to fix on your car; start by inspecting the lower control arm bushings and tie rods if you’re able
Keeme123 (08-25-20)
Try this. After driving around, preferably after healthy braking, walk around and feel each wheel hub. If one is noticeably hotter you will have found the problem brakes/hub. Careful doing so, it can be dangerously hot. It can be a sticking pin, caliper, very bad bearing, rotor, etc.
