How to get 6 cd cartridge out of ES300
Thanks, I believe I tried that. I will try again and see if there is any result. thanks for your response!
I think this CD Changer may be the problem that is causing my battery to go dead occasionally.
To get it to release if it's non-responsive, you need to take it out of the console and then get it to eject. It varies by model; single units usually can be made to release via detents on the side; changers usually require opening it up (which is tedious). If you google you can find the solution; I have in the past but no bookmarks, sorry.
If you think it's making a draw, you can do a drain test. Recent good info here, or google 'parasitic draw test.'
https://www.clublexus.com/forums/es-...diagnosis.html
If you have the budget take the opportunity to upgrade to a modern system. I personally like the Kenwood DDX5706S, pair it with Hertz speakers and a Hertz amplifier and you'll get stellar sound.
tonyzebra
02-06-05 08:59 AM
