2005 es330 lock beep
Hey guys,
im having a issue with the lock beep sound. When I try to lock it, it doesn’t make the beep noise anymore, how can I go forward with the repair?
thanks
thanks
Hello,
Do locks work as intended?
There is a dial under the Drivers kick panel, to the Right of the OBD2 port that adjusts volume of the beep sound. Try adjusting it and see what happens, if nothing, you can also check if the connector and the wiring to that dial are intact and properly secured.
Hope this helps and best of luck!
