Does anyone know how to replace the bulbs in the gauge cluster? I know how to remove the cluster and get the white plastic cover off the back to reveal the actual circuit board, but I can't figure out how to get the board loose to reach the bulbs. It's like the board it glued or soldered to the gauge faceplate peice. Not sure which LED bulbs to use either.Any help would be really appreciated.
I found a thread on how to do this, but it's for the previous generation which has a different gauge cluster. This is the cluster in my car.
From what I can gather from posts/threads on this forum there is no user replaceable bulbs they are soldered to the PCB. If you're not into soldering and general board rework this place may be able to help. https://www.taninautoelectronix.com/...gnosis-repair/
