Knock sender p0330
Car is a 2001 es300 about 150k miles. The p0330 (knock sensor bank 2) comes on when I drive above 65mph. Otherwise it stays off. I’m able to reset it and it stays off till I reach above 65 mph. Even with check engine on, drives perfectly, (p0330 and traction control light on)
Any thoughts? As I said if I erase codes and stay below 65 mph it’s fine
Hello,
It may be that the issue occurs as a result of high RPM, try driving around neighborhood in 2nd or 1st gear, just to keep the engine at about 2500-3000 RPM and see if the CEL will appear again.
Other than that, you can also try flipping the wires on the ECU or on the sensor wiring to see if the code will jump to the other bank, but you need to be extra cautious about it. If after flipping the contacts, the code remains the same, then it is likely an issue with the wiring or the ECU, but if the code switches to the other bank, then something is wrong with the knock sensor or its respective wiring.
Hope this helps and best of luck!
Thanks Arsenii, good suggestion. I’ll try the high rpm trick. But let’s say that it comes on at high rpms only, can I drive it as long as I keep the rpms relatively low?
And what if it doesn’t come on at high RPMs
Also, are Dorman knock sensors from Amazon any good?
If, however, the code is fixed to a certain speed rather than RPM, then it could either be an issue with the ECU, or some quite peculiar fault in either a wiring or a sensor, which is to be determined by flipping the terminals for the sensors, as I described in my previous post.
As for any parts made by Dorman, I would suggest to avoid them at all costs, those are some of the lowest end parts you can get, ask me how I know.. OEM Denso is definitely preferred, but those can very well run you a few pennies. Other alternative would be to get NTK sensors on RockAuto (P/N: ID0166), while I haven't personally used them, I am pretty sure those will still be far more superior than Dorman or any knockoff Denso stuff you can get on eBay or Amazon..
Hi Arsenelli, I tried duplicating the problem but no go. All is ok and no check engine light. So I’ll wait a bit more to see what happens. I remember I was driving on the highway about 6 months ago and I was in 2nd gear by mistake. Engine was revving higher than normal so check engine light came on. Unfortunately I don’t remember the code but I know for sure it wasn’t a knock sensor code. Oh well I’ll wait some more
so thank you.? Ya I’ll go for OEM knock sensors for sure
thanks again
P.S. On the highway in 2nd gear..? Sounds rather like a money shift scenario.. Maybe your current issue is a sweet revenge? Those cars can be pretty vicious at times if mistreated..
Not yet, it happened only twice in the last 6 months or so. So for now all is well each time was a different code only the last one was a knock sensor code. Don’t remember the first code. Both happened at speeds over 65 mph. Tried to duplicate problem but wasn’t successful yet.
for now car runs perfect.
mervin
10-20-08 11:23 AM
Lazy
08-29-07 05:07 AM
