Little vibration 97. With 91k miles
Bought a clean 97 with 91k miles. New tires. The car has a little vibration on the freeway. What would be some worn parts that might add a little vibration ? Thanks
Almost always tires. In rare cases a bad axle can cause this but it has to be pretty far gone.
So was it tires? Ball joints can cause the tires to bounce around but the joints have to be really bad and be making a heck of a noise.
Was the vibration an existing problem or after the new tires?
Although the tires are new, the balance could be off. Bring it back and have the shop recheck the balance.
Just a little vibration in the steering wheel at 65. Mph. It’s a old car so hard telling. Im guessing since it only has 91 k miles. All metal parts are ok. Most likely something rubber has just dried out from old age. Mechanic said maybe ball joints. I might try a suspension shop.
I have a small vibration at highway speeds and it was confirmed to be a wheel issue. A road force balance has drastically reduced it but my wheels are from another car and unfortunately in poor shape. If I ever get around to them I would get them all refurbished to be perfectly straight.
Usually wheel straightening/balance is around $150/wheel.
Yeah I noticed you got Michelin tires. The issue can still be with the wheels. I had severe vibrations on used rims with new tires. The rims were bent and it only got better after getting them straightened and rebalanced two times.
I haven’t had any luck reducing vibrations with an alignment. Alignments usually fix pulling to one side. Still a good idea with new tires but it won’t fix vibrations.
