Replacing entire door
I have not been able to find any videos or resources that show how to remove and replace the entire door. The only info i have found is about removing the door paneling inside. Any help?
Easy job. Remove the door check arm from the body, then remove the kick panel (not door panel, piece right under the lower dash) so you can unplug the connectors. Push the connectors/boot out and free of the door frame. Then remove the bolts holding the hinges to the door. Door is fairly heavy.
If this is the rear doors then same deal except you're removing the plastic panel where the seat belt is.
Artvipout
10-11-11 12:09 AM
