'96 ES300 passenger door won't opern
I have a 1996 ES300 that has been having problems with the front passenger door opening. You can't open it from the outside, only from the inside. Also, that window rattles when I'm driving. So, it's possible that the problems are related. I couldn't see that the window was broken and it goes up/down without any problems. Has anyone else experienced the same problems? Anyone have any ideas how much these problems might cost to get fixed? Thanks.
Hello,
Only way to know for sure what's going on there is to take the door panel off and inspect window rails, motor and the door handle. It is pretty easy to take the door panel off of car, even if you have never done that before, here you can find a Parts Diagram that shows all the fasteners that hold the door panel to an actual door, and here is a guide on how to take it off, while it is for a 1993, the process should be the same.
Hope this helps and best of luck!
