P0441 P0446 Did Smoke Test, Leak at Vapor Canister Purge Solenoid, next steps
Hey All,
I had a P0441 P0446 code, did a smoke test at a local indy shop, they said the Vapor Canister Purge Solenoid (part # 25860-20020) was the cause of the leak.
They reset the CEL.
That was on Oct 21st 2021.
New part (25860-20020) is available locally.
Questions;
1) Its been 3 weeks and I have been daily driving the car, maybe a 100 miles, the CEL didn't come back on, is the problem resolved by itself? Should I bother going through with this part replacement ?
2) Can I do this myself (save money on shop labor)? If so, how do I go about it?
PS: I do notice a slight oder like oil (maybe fuel) in the cabin, is that related to this?
I searched the forums and didn't see related answer posted.
Thanks
Car: 1998 Lexus ES300
They reset the CEL.
Questions;
Thanks
Hello,
I've had a P0440 and P0446 codes a while back, P0440 was a result of a bad gas cap, and P0446 was caused by a Purge Valve that got frozen in place due to rust. They were only coming up once in a blue moon for a while, after which I would reset them and drive as if nothing happened for another half a year or so, until they started appearing more like once a week, which is where I finally went to diagnose them.
I have a 2000 ES300 where they moved the Charcoal Canister on the bottom of the car, near the gas tank, yet I still managed to replace the valve without even lifting the car. Your Charcoal Canister is located under the hood, so it is just a matter of unscrewing one bolt and disconnecting a few vacuum lines; here is a Parts Diagram that shows the location of the valve to make things easier, you can track the valve down by following the hose from a Pressure Sensor on the Driver's side. As for the part to use, I managed to adopt a valve from under the hood that I found at the junkyard in descent condition (90910-12196 instead of 90910-12198), that way I didn't have to pay about $70 for a new one. Yours is even easier, since all the hoses on it face the same way, so it should be plug-and-play for you.
Hope this helps and best of luck!
Hi Hap7,
So i didn't end up doing the fix,
I went in for a smoke test as mentioned in my post and they reset the CEL at that time;
Since than I put over 1500 kms, and the CEL light (and the code) didn't come back.
I was ready to do the fix once the light came back on but so far so good.
Maybe the smoke test cleared out the piping kinda like blowing through it.
Piraiba
12-03-13 04:07 PM
