'95 ES300 stereo amplifier and power antenna?
Yeah, that whole write-up I did was about the subsequent ES300 generation (3ES) amp bypass…
I gather that your new head unit sounded noisy while plugged into / “integrated with” the factory amp. No surprise. Now, your Kenwood lights up but you’re no longer getting sound from the speakers. Correct? If so, your assumption about a failed factory amp makes sense (although it’s possible you simply messed up the installation while trying to eliminate the noise :-).
As I understand it, your ‘95 2ES has its factory amp located under the passenger seat. Since Metra specifies the same 70-8112 harness for your 2ES as is used in the 3ES to connect an aftermarket head unit, it’s likely that the same connectors are used on the amplifier end for the wire bundle from the head unit and then out to your factory speaker wiring (making this a logical place for you to locate an aftermarket amp).
It would probably make sense to collect/discuss more details, like some images of your factory amp’s location and (female) connectors and the (male) connectors going into it, in that other thread… I’m suspecting that the 2ES is similar connector-wise and the location of the factory amp & speaker wiring is the main difference, so I would be willing to entertain further questions about amp selection and subwoofer decisions there and ultimately annotate that OP with some “2ES notes” for the next person in your position (even though 2ES and 3ES units getting stereo upgrades these days are becoming pretty unusual :-).
As I understand it, your ‘95 2ES has its factory amp located under the passenger seat. Since Metra specifies the same 70-8112 harness for your 2ES as is used in the 3ES to connect an aftermarket head unit, it’s likely that the same connectors are used on the amplifier end for the wire bundle from the head unit and then out to your factory speaker wiring (making this a logical place for you to locate an aftermarket amp)..
sparkyguy
04-24-15 03:12 PM
