Corner Light retainers
I wanted to know where can I purchase those retainers (pins/screws) to hold the front corner (turn signal) lights please.
For my 1998 Lexus es300.
Thank you in advance.
Hello,
There are two clips and one screw that hold the corner light in place, both of those clips are not serviceable, if they are broken, you may end up needing to replace the light, the glue is not the best option for something like that in my experience. As for the screw, I believe it is possible to replace the grommet in which it screws into with something like this, but you will have to verify it..
Hope this helps and best of luck!
Ls430es300
03-26-11 10:15 PM
