Hole in air rrsonator
Was fiddling around with the car and came across the air resonator. Making sure everything was ok and found that there is a small hole on the side, and was wondering if it is suppose to be there. The hole in in the second picture. Upper right hand side of the box. The picture is a little crappy but still can see it.
Hello,
EDIT: Actually, it appears to be a hole for the clip that held the EVAP hose nearby, so as long as this hole doesn't go into the intake system, you should be fine. Part Number for that clip is 90469-12014, it shouldn't be too difficult to get.
Other than that, your hose clamps look busted, not sure what took place over there, but it appears as if someone twisted a heck out of them, so it is also a good idea to pick those up as well while you are at it.. Part Number for the first one is 96111-10880 and for the second one is 96111-10850, though I am not sure at what the difference is. They should be easy to find at any junkyard.
Hope this helps and best of luck!
Hello,
it does help alot. Thanks
enigma9o7
04-27-15 08:17 AM
tru2au
04-22-15 03:55 PM
