Need door help
Need door help
So I was recently in a wreck in my 98 Lexus ES300 and my front passenger door is not fixable could I use a 2001 Lexus door on my 98 car? And will everything connect and work the same! I need answers!!
You're in luck you can use the 2001 door it will bolt straight up and plug in. If you don't already know, car-part.com is a good resource should be able to find a door in your colour no painting required. This is also a good resource.
https://www.hollanderparts.com/
