Air Intake Replacement
7th Gear
Hello! Does anyone know where I can find an air intake for my Lexus ES300 from 2002? I've look on the internet, but only found ones for different years than my model. It doesn't have to be OEM, it just has to work.
Another important question - How do I properly replace mine? I also couldn't find any videos, and I don't want to break my car. Thank you in advance!
Hello,
What happened to your current intake in the first place?
What part of an intake are you talking about, Air Box, Piping or Intake Manifold?
The intake system appears to be identical to the one in similar year Toyota Camry, there should be plenty of them at the junkyard, which will be the cheapest and fastest option. If that won't work, look around local partouts, it will be a cheaper option than getting one from eBay.
Hope this helps and best of luck!
7th Gear
Hello,
I wouldn't mind replacing the entire intake system, it'd be great to see some extra HP in my old car. Plus, it would make for a good start in fixing cars.
99custom
03-20-18 05:53 PM
