Heavy Coolant Leak Please Help
7th Gear
Hey guys I got an issue today. So I have a 03 Es300 and I’ve had coolant problems in the past with a leak and found it was a clamp before. Now its leaking more now and I’m trying to find the leak and I just can’t find it. When I squeeze the hose connected to the thermostat housing I can hear the hole. But I cant see anything coming out. Only under the car I can see a constant drip! The location of the drip is almost directly under thermostat housing on driver side about parallel from the front left wheel. Any advice would be appreciated. Thank you in advance
oh and I don’t have any white residue under my oil cap.
Assuming your radiator is not leaking could be the bypass hose under the intake see here 16261G
https://www.japan-parts.eu/lexus/us/...t/2?pnn=16261G
4NGEL (06-11-22)
7th Gear
im going to look up some videos on replacing I think it’s gonna be a tough job but I think I’ll be fine as long as I mark everything and take my time and video everything.
7th Gear
7th Gear
I have a question in this photo. Am I supposed to have coolant in the area where it’s visible? Was I supposed to drain it before I started doing all this? I’ve been watching videos and everyone I’ve seen they didn’t have coolant in that hole in the bottom right? And is it 100% necessary to replace the gaskets every time you open it up?
What you're seeing is coolant passages in the head the larger openings are air intake. Please get rid of that green coolant and use Toyota Super Long Life if you don't your coolant system will rot out. Lexus should have used an all metal pipe older V6's have it.
Draining the coolant makes the job less messy also be very careful not to get coolant into the cylinders too much and you'll bend connecting rods.
The following 3 users liked this post by LeX2K:
Adam0412
01-25-13 12:16 PM
