Halogen Headlight Upgrade
Hey all,
I've been wanting to upgrade the headlights on my ES300, and I really like the look of white/blue bright headlights. Not the NASA spaceship highbeams that blind everybody, even during the day, but just a more modern looking headlight.
I've cleaned and polished my headlights, because when I first got the car, they were dirty as hell. But even with that, the current headlights are fairly dim at night. So I'd like to get some brighter lights as well as update the color temperature to be more modern.
Would definitely want something like the 6000K Nitro Blue.
I dig the look of halogen bulbs, and never really been a fan of LEDs (mostly on headlights where you see the individual lights), but I could see how having LEDs might be a better long-term investment.
Does anyone have any experience swapping out their OEM lights with halogens like this:
Ebay Halogen Headlight Kit
This might be a stupid question, but I'm assuming the with the halogen setup, you just need to swap out the bulbs with the color temperature you want?
The goal is to keep the headlights looking mostly stock, though I'd like to black out the housing eventually.
I found this picture with what looks like smooth fog lights, instead of the vertical line pattern, and was wondering what those are called and where I could get a set? I know this is a JDM Windom, but is there an option that would fit the ES? I love the clean and simple aesthetic.
Thanks for any help!
Hello,
If your only goal is to make the headlights look more modern, the easiest way would be to just get different light bulbs, like these ones for example, they have a higher Color Temperature, so they will appear more blue-ish than stock, without melting everyone's eyes down the road.
I would say I am quite skeptical about LED bulbs in headlights that weren't meant for it, you need to have a perfect match between the light bulb and the reflector for the headlight to function properly. Here is a thread on the subject with links to lights used.
The most complicated way would be to get HID, or Xenon headlights off of post-facelift ES300. The beauty of them is that they don't have any filament in there to begin with, they are filled with Xenon gas that, under very high voltage, begins glowing. Those headlight are quite efficient, but they do require a ton of other equipment to function, like the Driver to generate that high of a voltage, as well as a separate system to control the aim of a light. HIDs have very high light intensity, so if they are misadjusted even a bit, like if you were to fill up the tank from empty, they will become a road hazard, hence why they need an automatic aim adjust system.
The picture you linked is indeed for a JDM Toyota Windom, but in terms of exterior styling, it is not that much different from the post-facelift 2000-2001 ES300 offered here. If you can find a front bumper with fog lights off of one, it will fit right up to your car.
DIY Halogen Kit, I am honestly not particularly sure what are they referring to there, since about 90% of road cars used to be equipped with Halogen lights from the factory, yours included. Halogen is just an inert gas that they fill into the bulb to prevent the air from oxidizing the filament, as well as to improve heat transfer and adjust color temperature. My only guess would be that this kit is dedicated to people who had HID headlights from the factory, even though there isn't much to modify.
Hope this helps and best of luck!
Careover (08-07-22)
Hello,
In case of your car, ES330 is what got to be a facelift for an MCV30 model, it received the same basic kit of upgrades for the exterior, engine gained 0.3L, now called 3MZ-FE, new-ish transmission, and the same set of exterior upgrades.
I knew that the ES has a fancy startup when it was dark outside and the lights would "auto adjust" and didn't know the inner workings until you explained it. It seems like I'll be heeding your advice and will buy an OEM style brighter bulb that can be easily swapped out and not going LED.
(I painted the chrome trim black, btw)
Do not touch the glass in the process, it will ruin the bulb, and whatever you do, do NOT try taking the bulbs out with the Headlights on, there is enough voltage to strike through the human body, while it likely won't kill, it will definitely leave some sweet memories and twitchy eye for years to come.
Thank you for your explanation so far. I guess I might as well just pick up some much cheaper bulbs and see how that goes before buying whole new headlights. I wouldn't be opposed to doing that though, since mine have a couple serious chips in them.
Not really.. Facelift is just a mild, mid-run refresh, leaving the majority of the car intact. In case of MCV20, generation in question, it was produced from 1997 to 2001, getting a facelift in 2000, most major changes being an introduction of VVT-i system for the 1MZ engine together with the new transmission. For the exterior, it got new bumper with more integrated fog lights, two spoke grill, cleared tail lights, 16 inch rims instead of 15 inch ones, small changes like this to stay competitive before the end of model run.
As I wrote before, that means you have HID, or Xenon headlights, they don't have regular light bulbs that we come to expect, per say. Depending on the mileage of your car, Xenon filled bulb can get worn out, but more likely than not, it is the Driver that is at fault. To know for sure, you can carefully take each bulb out and swap them around to see if the malfunction would switch to the other light. Do not touch the glass in the process, it will ruin the bulb, and whatever you do, do NOT try taking the bulbs out with the Headlights on, there is enough voltage to strike through the human body, while it likely won't kill, it will definitely leave some sweet memories and twitchy eye for years to come.
Okay so I guess Halogens are standard, and if I really wanted the blue/white look, I would have go the xenon or LED route. Do all Halogen bulbs plug and play with most headlight units? I'm looking at the Philips Crystal Vision pack of 2.
Are Xenon bulbs plug and play with the halogen housing? Or would I need a different headlight housing/wiring kit for that? I installed an upgraded wiring harness for a Jeep I used to have, but that was years ago, and I'm basically new to mods again, especially on a smaller car like the ES.
The vertical pattern that you are referring to is just a design of a lens, any pre-facelift car, the one that was produced between 1997 and 1999, will have the same exact fog lights, with vertical lens pattern present.
Here is a link to an aftermarket bumper for a Facelift, it should fit your car, and here is a listing for Fog Lights to accompany that bumper.
I have a 2000 Lexus ES300 with smooth fog lights, it is in US alright, and I didn't have to hunt them down, below is a picture. Other member on this forum, LeX2K, has a very clean 2000 ES as well, here is a link to his album.
Pretty close but my passenger was the one that has the worn out/different color, this weekend I plan on taking out the bulbs and will do a visual inspection then will visit my local auto parts store to see if I can swap out the bulbs for the color I want. Since I bought this car ay 160K miles sitting pretty with 190K now and didn't know that my bulb was a different color all these years due to oxidation. But yeah will make sure not to touch the bulb thanks with the headlight information
If you have auto-aim, you have HID, or Xenon Headlights, refer to the video below for more information about what it is and how it works.
Xenon filaments is not a light bulb in a sense that we used to think about it, it is a capsule filled with Inert Gas. Not a lot of car parts store will have those bulbs in stock, and most of the time, when the color changes like that, it means that the system is not functioning correctly. Swap the bulbs around to see if it is the Driver, or the Bulb itself at fault before buying anything, stuff for HID headlights is expensive.
Thanks for the links. Too bad the bumper is out of stock, but I'll do some hunting on eBay. I guess I was looking for Windom parts, and couldn't find anything, which was before I realized the newer ES models were the same thing here.
On the facelift, I guess I'm possibly blind and possibly an idiot. Only way to learn is to ask though ha. I didn't even realize about the differences in the bulb H-numbers, like H11 vs H7. So thanks for pointing that out.
Yeah, now that's what I'm talking about!. So fresh and so clean. I wish my paint looked like yours .
Not trying to ask redundant questions, just new to this stuff. I appreciate your patience, and detailed information. You're definitely steering me in the right direction, now I have more stuff to look up
Vicati
06-08-22 07:17 AM
Rock-a-Lex
02-28-10 11:42 AM
