Is there a washer on the fuel pressure damper?
I had a leaking damper so i replaced it with an aftermarket one. I used the washer that it came with. Then bought an oem damper but I don’t remember if the original one I removed came with a washer or not. So now I have a choice to re use the aftermarket washer or just remove it
https://parts.franktoyota.com/oem-pa...ket-2323241081
Assuming you have a 3ES probably the same washer for most any Toyota engine with a timing belt but that's a guess.
prooh (08-11-22)
berritraz
04-25-22 10:43 PM
ScSlide
Performance & Maintenance
11-07-09 07:14 PM
