1997 ES 300 Stereo Replacement
1st Gear
Hi, All -- I have scrolled through several older threads on this topic and there is sometimes conflicting information. I am hoping to get some ground truth. My son is getting ready to turn 16 and will be getting my 1997 ES300. I'd like to put a modern stereo in it for him -- not something with a touch screen and a lot of buttons to push, but a straightforward Bluetooth/multimedia receiver. Here are some questions:
Thanks, in advance -- all advice would be appreciated.
Matt
- It sounds like I want to leave in the factory amp behind the glove box and use that. Why? Just to make the install easier? (I plan to leave it in, FWIW.)
- What are the implications for head unit selection if I use the factory amp?
- What are the implications for speaker selection? Impedance?
- Specifically regarding speakers, I've seen different folks recommend anything from 5.5" to 6.75" in the doors. It sounds like all would work, but with varying levels of modification. Which size would be the easiest to install?
- The subwoofer in the back is rattling, so it definitely needs to be replaced. Anything I need to be keeping in mind about that? Does the whole back deck need to come out?
Matt
Get these
Scosche LS2081B (buy while you can, sold out in most places)
JVC KW-R950BTS (has Bluetooth, time alignment, 24 bit DACs)
I don't know of a way to use the factory amp recommend you replace it with aftermarket. For speakers that is an open question greatly depends on your budget, same with the amplifier.
I have the previous version, KW-R940BTS it's a great unit feels a little cheap but sounds excellent Bluetooth works perfectly.
Matt
Matt
It's unfortunate, but capacitors on electronic mother boards (of the era) do tend to swell over time and then they leak and your mother board comes to a grinding halt.
It really doesn't matter if we're talking about the head unit or the main amplifier, the problem will eventually attack them both and usually, it proves to be fatal.
As mentioned, Scoche make some very nifty pieces of equipment which allow us to replace OEM head units and amplifiers and then mount new stuff as if it always belonged in place.
That said, a 1997 ES300 is an excellent platform for a young man's first car. Keep us informed on your progress.
AndyG
02-14-11 12:44 AM
ProfessorP
21
11-03-08 08:07 PM
