06 es 330 Lucas power steering stop leak
3rd Gear
Hello my car has 237k miles and it loses power steering fluid while driving over the course of a day(around 150-200miles) the power steering fluid will be empty I wanted to know if any has tried the Lucas power steering stop leak in this vehicle
Probably won't help for a leak that bad. Most likely you need a new high pressure line.
https://www.rockauto.com/en/catalog/...sure+hose,7320
If the power steering fluid has never been changed the pump itself may be leaking. BTW, Lucas will not harm anything you could give it a try.
amari243 (03-01-23)
I have replaced both my line and pump around 300500k miles. You can get a free estimate from https://www.yourmechanic.com/
Buying your own parts will save you more money.
- 1998 ES300 (356k miles)
- 2012 LS460 (70k)
- 2012 LS460 (70k)
amari243 (03-01-23)
Just a word of caution. Just bought a 2005 ES330 and the previous owner used a radiator stop leak with metal in it. Not good. Out of caution replaced the rack, pump, hoses and reservoir.
amari243 (03-01-23)
The high-pressure hose from the pump to the rack might be the most common issue. I replaced mine with an after-market hose for $60 and did the work myself. It's challenging to replace. I followed a couple of different Youtube videos.
amari243 (03-01-23)
