EFI Fuse or Relay
EFI Fuse or Relay
Hi
I have a 2008 ES-350 and I am getting a a VSC code plus check engine light and red triangle. I have read dozens of posts and concluded that it might be the EFI fuse. I find posts about the the wiring diagram for the EFI fuse which do me no good. Can someone tell me the number (not amps) of the EFI fuse as set forth in the fuse diagram in the manual?. If it is an EFI relay would someone please identify the relay by number as depicted on the diagram in the manual. Thank You
You need a code reader to retrieve the codes. You won't have any check engine light if the EFI fuse is blown.
aslowdodge
10-05-20 12:07 PM
JohnnyCake
09-22-14 01:58 PM
