Drive belt change by age/miles
When is the good time to replace drive belt? Is it every 100k miles or 7 years? It looks OK from outside. Also, what is the typical labor time on this if you have it done in the independent shop? I purchased OEM belt.
Mine has 140000 miles, on original belt. It looks fine and no squeaks.
I replaced the roller bearings once.
Most of the wear is inside of belt. It will likely have fine cracking. If it has deep cracks, replace it. That said, my ocd has me replacing the belt at 100K, along with coolant and thermostat. I also replace the pulley bearings. The belt is relatively easy and should take a qualified mechanic less than 15 minutes to replace. Have them check each pulley-bearing for wear.
tolian21 (04-23-23)
Like I said, mine is 2007 and 140000 miles, the belt looks like new.
If they did not see any oil or debris, they can go for very loooong.
The following 2 users liked this post by tolian21:
sthpawil (04-29-23),
Wilson2000 (04-26-23)
Actually, in most cases, the aftermarket is 10-20 bucks more expensive.
Replacing the serpentine belt is relatively cheap preventative maintenance.
If you can change your own oil, you can probably replace the serpentine belt yourself. You just have to be mindful of the belt routing. You will want to remove the front passenger side tire in order to have access to the serpentine belt from below, so you'll need to put the car up on jack stands. Never get under a car that is held up by only a jack.
Harbor freight sells a $18.99 tool for the process. https://www.harborfreight.com/serpen...kit-63689.html
Serpentine belt: Toyota P/N 90916A2010 (Replaces99367-C2090). Only buy from a Toyota or Lexus dealer. Do not buy from Amazon or eBay!!!
I purchase a lot of my parts online from Grieco Toyota https://parts.griecotoyota.com/oem-parts/toyota-serpentine-belt-90916a2010
