New Guy- Now Responsible for the Care and Feeding of Two ES350s
2nd gear
My college age kids each just bought their own first "real" cars with their own money- an '07 and '08 ES350 with 170k and 130k miles on the odometers, respectively. Both have good service histories.
Dear old dad (that's me) has offered to help them with maintenance while they're both in school, having maintained their high school beaters in the past (an e39 BMW 5 series and an '04 A4 Avant.)
I'm already tackling my son's '07 this weekend with a coil and plug change due to a #3 cylinder misfire code- while I'm there I'm going to give it an oil change, which leads me to my questions:
-What brand of oil does the group here like? I'm already planning on using a high mileage synthetic.
-Is there value in running a motor flush treatment like Seafoam or Liqui-Moly engine flush prior to the oil change? This is something I did on both the Audi and BMW but didn't know the value of doing on a Toyota engine.
-Random question: What's the torque value of the nuts retaining the strut brace/cowl to the strut mounts?
Thanks in advance, and I'm looking forward to being a part of this group.
Put a can of Seafoam, drive it for 200-300 miles and do an oil change. I use OEM oil and oem filter but Mobil 1 is also fine.
Gstaad (06-24-23)
Gstaad (06-24-23)
Yes, and his current (good) fixation is the 2GR-FE, it's great to see that he is able to do some teardowns while repairing his customer's cars so he can show us the insides and provide his commentary.
Bonny (05-12-23)
Gstaad (06-24-23)
I used Mobil 1 on my Lexus and Toyota vehicles for decades. Then, Project Farm tested all the oils and found some less expensive brands tested just as well as Mobil 1, including Walmart's and Costco's house-brand, full synthetics. They also rated Penzoil Ultra Platinum very high, and it is significantly less than Mobil 1. For oil filters, I stick with OEM or K&N.
Be careful when changing plugs on the rear bank. Some have reported broken wires on the harness that powers the coils after doing a plug change. Use only true-OEM plugs/parts, bought from a legitimate dealer. Many online dealers on Amazon and Ebay are scamming buyers with counterfeit (fake-OEM) parts. I've been burned once.
I have almost 100000 miles of experience with my 5ES, I changed the oil/filter every 10000 miles until CarCareNut said what he said about long OCI. Then, I started to do OC every 5000 miles.
I went from Amsoil 5W30, Amsoil 0W30, Mobil 1 0W20, Mobil 1 5W30 and at the end TGMO 5W30.
The best oil for this engine is TGMO 5W30 and OCI 5000 miles. When I run 10000 miles between OCI very often I heard VVT gear rattle at startup. With 5000 OCI all is smooth and quiet.
Yes, the 5K interval is key, however, I still recommend a full synthetic with a full package of additives. I would not say "any oil will work fine" as cheap oil with a minimum of additives can result in thermal breakdown residues gumming-up the rings/ring-grooves. Too, generally, cheap oils don't provide enough dispersents, wear protection, and other protective additives, like the better, full synthetics do.
ESh (06-28-23)
You are 100% right.
I'm not saying one can't use non-synthetic, no-name, oils in an ES without trouble. I'm saying I like to run the best possible oil to increase my odds of getting many hundreds of thousand miles on my ES without major engine trouble.
My 2001 Tundra has 125K miles. I've changed the oil with different brands of full synthetic every 5K miles. I took the valve covers off recently to change the gaskets and was astounded how new the valve train and top of the heads looked--no visible gum, varnish or residue of any kind!
