A/C Adjustments after evac and recharge
5th Gear
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
First post - happy to be here - could use y'alls input on my 07 ES350 AC issue. I changed out the expansion valve and condenser to Denso units and put a new Denso compressor in.
4.5oz PAG46 including the compressor oil and exactly 19oz refrigerant on the charge. At night it will blow 43 degrees F in 90 degrees
During the day in full sun and 110 degrees it will blow 70.
Do I add or remove refrigerant in order to make driving in the Arizona heat tolerable for my wife? Please help!
Let's go one by one. Why you replaced all those parts? Did you do it or the mechanic?
5th Gear
I was getting a slow leak that I couldn't track down so it was recommended to me that the factory compressor leaks internally and is likely the culprit so I replaced the compressor, expansion valve and condenser. No metal shavings anywhere - this was more of preventative maintenance than anything since the compressor had 180k on it.
Do you have the machine to create a vacuum before filling it up with the refrigerant?
5th Gear
Yes sir - it is a 4.5cfm vacuum pump. I pulled a vacuum for about 45 minutes and then let it sit overnight to make sure that it wasn't leaking anywhere. It was solid in the morning. Gauges didn't move
What are the pressures now?
viktorch
07-20-20 03:52 PM
