2008 Lexus ES350 clicking noise coming from rear brake
5th Gear
When I apply the brake I can hear clicking noise from rear brakes. I have troubleshooted as following
1) Checked the brake pads and rotor. They are good
2) The clicking noise is slow or fast as per the speed of the car
3) The harder I press the brake the louder the noise is
4) The noise does not come in reverse
Any suggestion what might be the problem?
5th Gear
I am new to this forum so I was not sure which forum to choose to post my question.
I did look at the video and will try the tips in it. In general I doubt it is wheel bearing cause it is not a grinding noise when the car is moving
Can you make a video?
Do you hear it from both sides?
There are many things that can click.
5th Gear
It's probably in the wrong forum.
But jack it up and spin the wheels freely, and see if it could be a bad wheel hub.
https://www.youtube.com/watch?v=vJYDGWEwhEk
Now another question for the fellow forum members. What is the best after market company for suspension part and wheel bearing. OEM wheel hub assembly is like $500
***, SKF…Lemforder.
Duralast are good.
Breitling
05-21-19 12:49 PM
