Touch Door Unlock?
4th Gear
Hi everyone. First post here. Hoping you guys can help me out.
Long story short, I have a new to me 2010 ES350. Door lock actuator and wasn’t working so I had it replaced. To my surprise not only could I now unlock the door via the fob, I could also do it using the door handle. I didn’t even know I had touch door handles until this point. I didn’t know what I was doing so I kept holding the door handle while pushing the black button. Anyway, I figured it out after a few tries that touch was unlock and button was lock. Worked great for about a day and a half then just suddenly stopped working. I can still unlock via the fob. All the other door handle touch sensors work for unlocking all the doors. But I get no response whatsoever when I touch the driver door handle.
What could be wrong? Could I have damaged it by being stupid the first few times? How do I fix this? Any and all input would be greatly appreciated.
Thank you.
Thank you.
4th Gear
I think your touch sensor has a bad contact. The door lock actuator should be fine.
4th Gear
You can fix if there is a short in touch sendor cables.
If the sensor is faulty then you must replace it.
Also, you can put the sensor from the rear door.
bdevlin197
07-04-11 07:33 AM
