Anti freeze leaking from transmission pan gasket
1st Gear
Anyone have idea on how coolant getting in transmission? I put in new radiator and filled it. Heard dripping under car and noticed coolant dripping from the transmission pan gasket. I disconnected the transmission coolant lines thinking my new radiator was bad and coolant was getting in through transmission cooler. Once transmission coolant lines disconnected, no antifreeze was coming out so now not sure how I could be getting coolant into the system. Front end is jacked up and only gravity feed. Haven't even started the engine.
Check the hoses that go over the transmission.
Can you post some pics?
yyymmm31
12-05-20 04:05 PM
