XM antenna flashing
XM antenna flashing
Hello all,
I have a 2011 es 350 with the XM feature. I want to sign up for XM again but the XM radio is flashing antenna on the display. I can’t change channels to 0 to get the radio id. I want to know where the xm antenna is located in the car so I can check to make sure plugged in before I rip out the center console to check the receiver. Any tips, hints, tricks would be helpful!
Welcome to CL. Here are a few links to similar threads and maybe they will provide answers for you. Then try your own search using the box to the right of the main page. Try using the word satellite and maybe antenna.
Finally you may have to consult with a car audio shop.
https://www.clublexus.com/forums/es-...tructions.html
and
https://www.clublexus.com/forums/es-...placement.html
and
https://www.clublexus.com/forums/es-...-on-radio.html
and
https://www.clublexus.com/forums/es-...t-working.html
and
and
and
