Vsc engine and trac light came on HELP!!
So I was trying to do a u turn and I wiped my car around and the traction light came on the check vac and the engine light came on. I checked my gas cap to see if tht was y cuz I know that can cause it but it wasn’t tht so I’m very confused and need help
You need a code scanner to see what the exact error is, you can take your car to AutoZone to get it scanned for free also, or just buy a cheapie from Amazon.
Also, try to listen closely to the car, are you getting misfires or is the acceleration sluggish?
If your CEL is flashing do not drive the car, it indicates that there is something seriously wrong.
Vsc issue and now melting
My son owns a 2009 es 350. We recently replaced the blue and black fusible links. All was fine for about a month until yesterday. Vsc came on and car dash lights dimmed and vehicle started losing power. Checked under hood and found the post and wire running off the black fusible link had melted. Any advice??? please help
Cshuman
12-10-21 09:44 AM
