ac codes 24 and 42, warm air coming out driver side, cold air passenger
6th Gear
So i have warm air coming out driver side and cold air out of the passenger side - pretty common problem from what i have read but no actual video of a fix on you tube. I have codes 24 and 42, the 'diagnostic code identification' list that is on this website doesn't have code 24. i did check the codes in the dark and i also read that it could be the sun sensor but i got a code 21 and that was listed as the sun sensor - so why is 24 also sun sensor, oh well.... but what i am really concerned about is code 42 which is air inlet door servo part number 87106-33260 which if i am not mistaken is also Lexus denso part number 063800 - 0172... can someone tell me where this part is located? Is this the correct part that i need? Any videos. Please Please help. I am desperate - i live in Florida and summer is coming
btw i have checked coolant levels, i did recently change the cooling fan module and i never disconnected the battery while i did it - fyi
2007 es350
2007 es350
See these older threads which I found using the search term blend. You can try other searches for more information if they do not help. The search box is on the front page, right side.
https://www.clublexus.com/forums/es-...t-cooling.html
https://www.clublexus.com/forums/es-...-07-es350.html
https://www.clublexus.com/forums/es-...tor-issue.html
https://www.clublexus.com/forums/es-...p-it-cool.html
6th Gear
Yes compressor engages
and please anyone feel free to reply to thread, still a little concerned if i understand code 42 since, i am conflicted about which servo
it is not the big disk looking servo though i hope, correct?
6th Gear
I gave you the position of the servo motor that I found through the part number that you gave me.
That is the servo motor air mix sub assembly.
So if that servo motor works then we should look at something else.
On the other side check for these two:
Note: they might move but the shaft can be broken so check if the door moves with the servo.
daweeze02
SC- 1st Gen (1992-2000)
15
12-12-10 11:23 AM
