My car not work lexus es350 2010
5th Gear
Hello, I use Google Translate and I hope that the translation is understood correctly
I have a 2010 Lexus ES 350 … Don't start working
The battery was replaced and the problem was not resolved
The operating fuse has been tested and is working properly. It was also replaced, but the problem was not resolved
The second copy of the key did not solve the problem
The predecessor's fuse location was tested with an electrical wire and it works correctly. I have attached a video showing the problem
You need to check 3 things:
#1 Fuel - check fuel injectors, fuel pump etc
#2 Spark - check spark plugs, coil packs
#3 Air - Check air intake filter, throttle body
Any codes? Buy a copea OBD2 scanner from eBay/Amazon/your favourite online shop and plug it in.
One question, does the car crank by pressing the power button?
5th Gear
I found the problem.. It was in fuse No. (48). When examined from the outside, it was found to be working well.. After removing the fuse, it was found that it was burning. It was replaced and the problem was solved.
The following 3 users liked this post by Mnmn911:
