I had a question about the rear wheelhouse liner for my '07. Essentially, the car lacks the rear liner on both sides, causing the rear bumper to protrude a bit on each side. My local Bodyshop guy said the protrusion could be fixed by securing the bumper to the (absent) fender liner.
I'm having difficulty locating a decent set to install on the car. Most I've seen are for the fronts and don't break the bank. Does anyone have any reputable sources from which to acquire these parts, or is there an alternative that could be implemented to solve the issue?
eBay has used ones or about $110 and both are from the same seller, a used auto parts dealer with an excellent seller rating. You should get these.
You will also need the clips etc to attach them to the vehicle. There are several options on eBay, but I don't know which are the best fit. I found them with the same search term - 2007 Lexus ES350 fender liner
Or if a body shop or your mechanic installs them, they will know what to use and can get the right clips.
