ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
ES350 Tires
Old 03-26-13, 06:08 AM
  #31
garsarno
garsarno's Avatar
Ditto C177Pilot. Always have done that on my cars. By the time you trade in the car, having a used spare tire means nothing versus a brand new one.
Old 04-01-13, 05:54 AM
  #32
Paul3637
Paul3637's Avatar
Default Make sure you get the math right !
Originally Posted by C177 Pilot
My 2010 ES has 37,500 on the Michelin Energy MXV4 S8s and are ready for replacement. I am satisfied with the longevity and really want the smooth and quiet ride. Besides, my spare has never been on the ground so I will buy three tires and use the spare, keeping the best of the worn tires for a spare. That will save $150+.
Go to tirerack.com and do a comparison shop.
You can buy Michelin Primacy MXV4 H rated for $150 each .... and you can buy Energy MXV4 S8 for $200 each. Thus, you can buy 4 new MXV4 Primacy for the same as 3 Energy.
Then compare the user ratings. Primacy comes out WAY WAY better. Primacy will go for 60,000 with no problem. Energy will go for 40,000 miles and on the tirerack survy, Energy owners say WOULD NOT BUY AGAIN !!!!!!
http://www.tirerack.com/tires/CompareTires.jsp
User rating of Energy: 4.2/10
User rating of Primacy: 8.1/10
Old 04-01-13, 10:12 AM
  #33
don6709
don6709's Avatar
Originally Posted by Paul3637
This has been beat to death here & over in Avalon & Camry forums. For example:
https://www.clublexus.com/forums/es3...s-350-a-2.html
http://www.toyotanation.com/forum/15...-avalon-4.html
http://www.toyotanation.com/forum/15...ml#post3990031
Toyota quit using the Michelin Energy MXV4 S8 and now uses Primacy MXV4 V rated as OEM on Camry SE, Camry XLE & Avalon.
Consumer reports and tirerack surveys rate Primacy MXV4 H rated as the best tire for an excellent balance of treadwear, traction, fuel economy, braking, etc.
For more spirited driving or if you live in the mountains on twiting reads, Primacy MXV4 V rated
or Primacy MXM4 V rated might be a better choice.
The OEM MXV4 S8's are a horrible tire by comparison ... and more expensive. Of course nothing is worse than the Bridgestone Turanza EL400 OEM that wear out in 15K miles.
This in and of itself proves that there was something wrong with the Michelin Energy MXV4 S8's. Why would Toyota swap it out for the Primacy Series if it was a good tire...
Old 04-01-13, 03:49 PM
  #34
Received 2,723 Likes on 1,950 Posts
I think Michelin is phasing the S8 out...
Its all about pricing, if its cheaper for them to use the Primacy, thats what they will use. The Primacy is a much better tire.
jhp012
01-20-08 10:10 AM
Citylights
12-09-06 09:40 AM
richbutler
06-08-06 09:01 AM
Quick Reply: ES350 Tires
